Beginner
Flexible JID: UDS for directory search and local users possible?
Hi everyone!
I have a new project for CUCM+IMP for a customer, so I was thinking to setup flexible JID.
Because of by the customer not all users are Active Directory users  (there are come external consultans working there), my idea was to use UDS for directory search for all users, synch with LDAP for AD users and create local user for the others.
Until now I could try to test the login with jabber from a PC that is not in the Windows domain. Discovering CUCM and IMP is working well using the email address of a AD user and also LDAP authentication is OK.
The only strange thing is, that in the upper area as user-id@presencedomain is displayed and not the first and last name of the user. Is because the PC is not in the domain?
The biggest problem is with the local users: even if for the local users there are directory URI and email in the CUCM configuration, it is not possible to login into Jabber.
Can you help me to find the right way to go? I have no experience with flexible JID.
Mirko
5 REPLIES 5
Rising star
Re: Flexible JID: UDS for directory search and local users possible?
I'm not 100% sure about the issue. The issue is that there are external employees that their PCs aren't in the domain, so this makes them enter their user URI all the time when they log in instead of auto discover the _cisco-uds and _cuplogin SRV records? If that's the case, and those employees are sitting in the internal network (only not in the domain) you can install their Cisco Jabber with installation arguments and set the service domain to be the internal domain, so that Jabber will be able to go and discover the SRVs under this service domain (that of course if those external PCs when they're on the internal networking are also getting the internal DNS servers of the organization via DHCP, if not, it won't work).
So, you can just go and install Cisco Jabber with arguments like that:
msiexec.exe /i CiscoJabberSetup.msi CLEAR=1 SERVICES_DOMAIN=domain.com
And of course you must set the directory URI of the local user in the CUCM to be their PC username as a user part URI, and with the 'domain.com', like that: username@domain.com.
Hope it helps.
Beginner
I will try to install Jabber with the arguments as you proposed and test Jabber login.
Yes, they are sitting in the internal network but not in the domain.
The local user in CUCM are still configured with the directory URI as username@domain, my doubt was if it is possible to have local users and flexible JID.
Thanks a lot,
Mirko
Hall of Fame Cisco Employee
Yes, you can have flexible JID and local users, IM&P doesn't care if the users are local or LDAP, it only matters the mail entries have the different domains.
java
if this helps, please rate
Highlighted
Beginner
Hi!
thanks for your reply, it works!
I have some local user and I cannot login with the email address, search other users, chat...
I have only a problem with the LDAP synchronized users:
these users can login, search, click to call and so on, but different to the local users they see the own user-id@presencedomain in Jabber and not first and lastname.
Here the jabber-config.xml file:
<?xml version="1.0" encoding="utf-8"?>
<config version="1.0">
<Policies>
<InitialPhoneSelection>deskphone</InitialPhoneSelection>
<ServiceDiscoveryExcludedServices>WEBEX</ServiceDiscoveryExcludedServices>
<Screen_Capture_Enabled>true</Screen_Capture_Enabled>
<File_Transfer_Enabled>true</File_Transfer_Enabled>
<Video_Disabled>false</Video_Disabled>
<EnableAccessoriesManager>true</EnableAccessoriesManager>
<EnableCallPickup>true</EnableCallPickup>
<EnableBFCPVideoDesktopShare>false</EnableBFCPVideoDesktopShare>
<TelemetryEnabled>False</TelemetryEnabled>
<DirectoryURI>mail</DirectoryURI>
</Policies>
<Directory>
<DirectoryServerType>UDS</DirectoryServerType>
<IMAddresses use-default="false">
<IMAddress>mail</IMAddress>
</IMAddresses>
<UseSIPURIToResolveContacts>true</UseSIPURIToResolveContacts>
<SipUri>mail</SipUri>
</Directory>
</config>
What could be the reason?
Mirko
Beginner
Hi!
In the meantime the issue is solved: the cause was that I hadn't change the the IM Address Scheme to Directory URI in the advanced presence settings.
Thank you so much for your help.
Mirko
Content for Community-Ad
August's Community Spotlight Awards
