I am looking for help with webex on Linux
achenampara
I finally got webex meetings working using the iceweasel 32bit plugin... However, I cannot use the computer audio and I get an error that the audio device is inaccessible... Has anyone else solved it?
I use Xubuntu 16.04 LTS
Also, per , There is no support for webex personal rooms... again, hoping that someone here has solved for it already..
-cheers,
ajay
Oleg Shornikov
Hello. Perhaps you found a solution to this problem?
