Interdomain XMPP Federation with Presence and Expressway C and E
eeelizondo
Hi experts,
We have a customer with CUCM 10.5, Presence 10.5, Expressway C and E. They want to federate with other companies with XMPP using Expressway C and E, and after reviewing all the documentation we could´t make it work. Does anyone have this scenario working?
Thanks in advance!
Jaime Valencia
The configuration for that is rather simple, have you reviewed the EXP-E logs to see what's failing?????
java
if this helps, please rate
Hi Jaime!
In the configuration of IM and Presence, do you declare a route? in Expressway we need to use always static routes or can it be automatically?
Thanks in advance!
Also,
In the logs we dont see anything, its like its not trying to establish a connection.
No, IM&P will already know that the XMPP route is via EXP-E
Whether you want it to be dynamic, or static, that's up to you
http://docwiki.cisco.com/wiki/CUPS/IM%26P_FAQ#How_to_configure_XMPP_federation_with_VCS_.2F_Expressways.3F.3F
There is also plenty of material on XMPP federation on PEC you might consider reviewing
java
