06-05-2015 01:15 PM - edited 03-17-2019 05:14 PM
Hi experts,
We have a customer with CUCM 10.5, Presence 10.5, Expressway C and E. They want to federate with other companies with XMPP using Expressway C and E, and after reviewing all the documentation we could´t make it work. Does anyone have this scenario working?
Thanks in advance!
06-05-2015 01:45 PM
The configuration for that is rather simple, have you reviewed the EXP-E logs to see what's failing?????
06-05-2015 02:33 PM
Hi Jaime!
In the configuration of IM and Presence, do you declare a route? in Expressway we need to use always static routes or can it be automatically?
Thanks in advance!
06-05-2015 03:00 PM
Also,
In the logs we dont see anything, its like its not trying to establish a connection.
06-05-2015 03:58 PM
No, IM&P will already know that the XMPP route is via EXP-E
Whether you want it to be dynamic, or static, that's up to you
http://docwiki.cisco.com/wiki/CUPS/IM%26P_FAQ#How_to_configure_XMPP_federation_with_VCS_.2F_Expressways.3F.3F
There is also plenty of material on XMPP federation on PEC you might consider reviewing
