06-13-2018 08:33 AM - edited 03-17-2019 07:35 PM
Jabber 12.0.1 - I haven't tried this yet. I have a few users iPhones and wondered if they could use a common jabber account. Will a jabber account work for multiple iPhones at the same time or androids for that matter ?
Solved! Go to Solution.
06-13-2018 09:20 AM
No, that would not be supported 1 TAB/TCT/BOT/CSF devices means call control for 1 of those devices at any given time. You would need to either get everyone their own account and use a shared line, or individual lines and use a line group.
06-13-2018 09:20 AM
06-13-2018 10:11 AM
06-13-2018 10:33 AM - edited 06-13-2018 10:34 AM
Yes, you can have any (or all) of those 4 options, and you can use them all the same time, but that's 4 devices, one of each kind you can have.
If you try to use two devices with a single device configured, afer you login, it will tell you that there is already other device registered to CUCM and if you want to remove registration from it, and use it in that "new" device, or not.
03-05-2020 07:47 AM
in my scenario have Citrix Cisco JVDI and i dont get this message. So in the end the user could be logged from pc and even from citrix. Is there any jabber config variable which will check if the user is logged or not?
Thank you for your reply.
Vit
