09-17-2015 05:30 AM - edited 03-17-2019 05:31 PM
Hello all,
os: windows xp 32 bit
cucm : 10.5.2
IM&P :10.5.2
It is a fresh installation and my jabber got registered via computer at fist , so i switched to check the connection via phone and it worked
when am reverting from phone to computer connect, it keeps on tuning setting phone....anybody can help me out
regards
balaji b
Solved! Go to Solution.
09-17-2015 08:00 AM
You probably want to start by using a supported windows version, XP is NOT supported with Jabber 10.5
IMHO there's no point on trying to troubleshoot a not supported environment you won't see with a customer
09-17-2015 08:00 AM
