Jabber 11.9 - Contacts not visible in client.
frank_wakelin
When using Jabber 11.9 a number of contacts added from the directory do not show in the client contacts list when added successfully.  When I examine the contacts list via the CUCM presence viewer they are present, but do not appear in the jabber client.  If I remove/add contacts back sometimes they appear, but may disappear again after logout/login.
This behavior seems to be the same across other platforms running 11.9 (iOS, Android) - but I have heard reports that logging jabber 11.8 show all contact successfully.
Yes the solution which Cisco TAC provided was to convert the local users as IM&P users.
Not sure why the same users works in Jabber 11.8 version upon adding as a Contact but not in 11.9 for which there is no response from Cisco TAC.
navidsyed
Hi Frank,
Have you heard anything from Cisco about this?
-Navid
we have exact the same problem.
Any solutions yet?
Florian
No, I didn't end up engaging Cisco on this one.  In my case there were some discrepancies with the users generated IM address, so I updated the IM address scheme and regenerate all IM addresses (this is a relatively new install).  Once I did that the problems with contacts seemed to correct themselves.
