Highlighted
Beginner
Jabber 12 Multi-line and Presence state
Does Jabber for Windows 12.0 with multi-line enabled allow the IM presence to update if the user is on an active call on a non-primary line?  I've looked through the release notes and guides but haven't seen that detail.
We're looking to upgrade our CUCM environment shortly and would find it beneficial if Jabber allows presence status's to update if any of the lines on the Jabber client are in use.
Thanks!
2 ACCEPTED SOLUTIONS
Highlighted
Hall of Fame Cisco Employee
Yes, the "on a call" status works across different lines in Jabber.
java
if this helps, please rate
Highlighted
11.5.1.14900-11
java
10 REPLIES 10
Highlighted
VIP Collaborator
Hi there
AFAIK, Jabber multiline concept is more like, more line for Phone-mode in CSF clients. You can add up to 8 phone lines per user. Say a replacement to Cisco CIPC.
After you have installed and configured Multiline, your users can:
• Select a preferred line for making calls.
• View missed calls and voicemails.
• Use call forwarding, transfers, and conference calls on all lines.
Multiline supports the following features on all lines:
• Far End Camera Control (FECC) and Binary Floor Control Protocol (BFCP)
• Hunt groups
• Call recording and silent monitoring
• Shared line, dial rules, and directory lookup
• Accessory manager
If Multiline is enabled, these features are only available on the primary line:
• Call pickup
• CTI control for the desk phone
• Extend & Connect
• Expressway for Mobile and Remote Access deployment
Min Requirement – CUCM 11.5 SU3
Cop file - cmterm-jabber-desktop-eight-Lines.k3.cop.sgn
 It’s included in the "CiscoJabber-Admin-ffr.12-0-0.zip", which can be downloaded from the "Jabber Software-12.0(0)" download area.
Refer Page 61
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/12_0/cjab_b_feature-configuration-for-cisco-jabber-120.pdf
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
Highlighted
This information helps, thanks Rath. We were hoping for a solution that'd allow multiple lines (at least 2) to be monitored and able to display "on a call" status if either line is in use.
Actually, our ideal solution would be if Finesse's "ready/not ready" states could be integrated into Jabber too. We have Finesse Agents who appear as available in Jabber but their Finesse state is set to "Not Ready" resulting in calls to their extensions to route to voicemail. This causes our operators difficulty trying to determine when they can transfer a customer call to an Agents extension for immediate assistance.
Highlighted
java
Highlighted
This is great news Jamie, thanks! Did you find this detail somewhere in a support guide? If you could provide that reference, I'd greatly appreciate it.
Highlighted
I tested it in my lab.
java
Highlighted
Thanks for testing. Is your lab running on CUCM 11.5?
Highlighted
11.5.1.14900-11
java
Highlighted
It's mandatory Whole Cluster reboot after install cmterm-jabber-desktop-eight-Lines.k3.cop.sgn?
Thx,
Matteo
Highlighted
I am sure you have moved on from this, but I am trying to get it working and am failing. We are on CCM 12.0.1 and CCX 12.0.1 and IMP 12.0.1, we have the Jabber 8 line device pak installed. Jabber multiline works great, and it also works great for Finesse users, however I am unable to get Finesse/CCX to recognize when my non IPCC line is in use. Is there anything special I need? All the user associations are present.
Highlighted
Beginner
nice data
Content for Community-Ad
