17627
Highlighted
Beginner
Jabber 9.5 wont connect to voice services
I have a user that is not able to connect to the voice services on the IPhone 9.5 Jabber app.  He is configured that same as my self and others, and it is working for them.  Really got me confused.  He does have an older version on the Jabber app that does work, but the new one will not.
29 REPLIES 29
Highlighted
Beginner
Thanks guys!  Thatv was the fix!  Anyone know about why directory not working?
Highlighted
I have the "Digest User" the same as the "Owner ID" but it still doesn't work - am I doing anything else wrong?  It works fine in Jabber Voice app
Highlighted
Hi Paul,
Try these settings and see if they make any difference.  Notice I have owner as anonymous and my owner id field is greyed out.  My mobility user id field does have my userid however.  I also have "enable cisco unified mobile communicator" checked:
Highlighted
Hello Dan,
I have configured as you suggested above but Phone Services still will not connect;
What's annoying is that the IM and Voicemail "Accounts" connect and work fine, just not Phone Services.  I really am not sure what I am doing here incorrectly as on Jabber Voice the Phone Services/Desk Integration worked fine.
One thing I am slightly confused about aswell is how it decides what CUCM it picks up.  Although I can't manually change it, the CUCM server it has picked up doesn't match the primary CUCM server dependant on the Device Pool I am in.  Its not an issue as the IP address it has picked up is a valid CUCM Subscriber but it just puzzles me where it is getting that info from.
Thanks for your assistance.
Paul.
Highlighted
Hi All,
I've already tried jabber for android 9.5 also.
But phone service wont work either.
iPhone work well.
Call Manager System version: 9.1.1.10000-11
IM and Presence Server System version: 9.1.1.31900-1
ATommy
Highlighted
HI All,
I've tried jabber for android 9.6 beta version.
But phone service still dont work.
Don't know what missing. iPHone and iPad work well.
ATommy
Highlighted
same problem here!!
phone services don't work...
Highlighted
Hi all just finished mi configuration you and i worked.
you just have to follow the steps on the Document and create the TCT acociate it with your user.
http://www.cisco.com/en/US/docs/voice_ip_comm/jabber/iPhone/9_5/JABI_BK_J38B2ACB_00_jabber-iphone-server-setup-9-5_chapter_0110.html
Highlighted
My problem is in jabber android 9.6. Can't log in phone service (presence work fine), i tried everything, reboot cucm, digest user, etc. But the state and ip address on cucm still unkown. Ipad, Iphone, Windows work ok on both (cucm and cup).
Highlighted
Beginner
Thanks guys
this worked fine, in the section "Protocol Specific Information"  put the Digest User , owner ID , and worked!!
now,  i can make phone calls .  Jabber  Android 9.6
we have
CUCM 9.1.1.10000-11  and Cisco IM & Presence 9.1.1.10000-8
Highlighted
Beginner
I have met the same issue.and seems no one can resolve this problem,annoying!
Highlighted
I just found a workaround (for Jabber for Android, iPhone works for me since the beginning) that worked for me and I think it's maybe useful and helpful. (I read about the kernel issues of many Android devices about large SIP messages over TCP).
The workaround is
- Copy the Phone Security Profile (under System > Security > Phone Security Profile) of "Cisco Dual Mode for Android - Standard SIP Non-Secure Profile" and name it Crazy Android - SIP Non-Secure Profile
- Force the Transport Type to "UDP" only. (change the Transport Type the default is TCP+UDP) and save.
- Apply the Phone Security Profile to the BOT device under "Protocol Specific Information" > Device Security Profile and select "Crazy Android - SIP Non-Secure Profile" (or whatever you named it).
- Save and apply settings. (I assume that the other parameters are correctly configured, you can have a Samsung Galaxy S4 or something supported like that which works perfectly since the beginning without any hassle, so to clone its config and just change the Security Profile parameter)
- Connect to Jabber for Android (the blue one! I tested this method with Jabber Voice (the green one) and it didn't work though).
- Login with Jabber for Android to IM & P.
- It worked for me (It's an Infinix Race Bolt Q smartphone, not very familiar hein)
I found some logic in this workaround since the problem is related to "large SIP messages over TCP". Turning this to UDP made things work for my chinese Android phone.
If this workaround worked for you, please leave a comment. (you may not rate me, I just wanna know if it works also for you  :) )
Highlighted
This worked perfectly. However, I am unable to hear any audio. What could be the problem?
Highlighted
Thanks for help, it works nice. But problem the same, like ngaruiya_254 describes.
Highlighted
Beginner
This worked. However, the phone is silent. I cannot hear any dialtone
