11-01-2012 10:50 PM - edited 03-17-2019 02:45 PM
CUCM, CUP and Jabber all from UC 9.0 NFR bundle:
- The CSF device has registered with cucm, device name is CSFuser
- DN has been associated with CSF
- Have associated user with CSF and DN
- Can place and receive call on deskphone mode.
- Can place call but can not receive call on softphone mode
- If unplug the deskphone and switch jabber to softphone mode, the calling side can hear the error prompt was "your call can not complated...."
Any advise will be hilghly appreciated....
11-02-2012 03:17 AM
Is the DN on the CSF device in a different partition that is not accessible to the CSS of the device you're calling from? That Annunciator error should only play when CUCM cannot find a matching DN pattern.
Please remember to rate helpful responses and identify helpful or correct answers.
11-04-2012 04:23 PM
No, it's not CSF device or DN class of control settings.
What else it could be
08-16-2013 10:16 AM
I am seeing the same behaviour. The line appearances on both the deskphone and the Jabber (does the same thing using CUPC) are in the same partition but the soft phone will not ring when called. I have a few remote users that need this to work as they dont' know when someone is calling them when they are working out of the office. Outbound dialing works fine.
CUCM 7.1.5
CUPS 8.5.3
I know Jabber is not suuported on CUPS 8.5.3 but CUPC has the same issue.
08-16-2013 10:39 AM
My issue ended up being a config issue on my ASA. I have a NAT hairpin statement configured for my remote site.
08-16-2013 01:52 PM
I think our problem was from the ASA as well, as we were using ASA to do the VLAN trunking for our LAN.
Could please paste the particular config which need to be done on the ASA?
Cheers
08-16-2013 11:29 AM
This is happening for me even within the network. I have my laptop running CUPC at my desk and when I dial my number from another extension my desk phone rings but CUPC does not. I have the CUPC client in soft phone mode. Deskphone control works fine but none of my CUPC/Jabber soft phones will ring on inbound calls in softphone mode. I have not tried setting up a soft phone that doesn't have a deskphone with the same DN on it. I may try that to see what happens.
08-16-2013 11:34 AM
Are your clients in a different subnet than voice? Utilizing voice vlan config on switch interfaces? If so try putting a desk phone in the client subnet (same subnet the PC would be in) and see what behavior you get.
08-12-2013 08:56 AM
I'm seeing this same behavior. What was your fix action if any?
