jabber clients for guests
bluesea2010
Level 5
Level 5
If I have guests in a remote location ,What is the best way or there is a way  to provisioning jabber clients
to them
Jaime Valencia
The requisites for Jabber would be exactly the same as for anyone else.
Exactly what are you trying to do?
java
if this helps, please rate
Suppose if we want to do video conferencing  and the remote user is in different company ,
How can I do in this scenario
You could use B2B (assuming other end has everything that is required) or use CMS with webRTC, I suggest you reach out to a local Cisco partner so you can get the right solution.
java
