Walkthrough Wednesdays
288
Jabber for Android not registering
Hi Guys!
I'm facing a strange issue with the Jabber for Android (9.6.0). It cannot connect to the UDS of CUCM and therefore it is not useable with the error "Networkservices not found".
Facts:
  • CUCM   9.1.2
  • CUP      9.1.1
  • Collaboration Edge is configured with another external Domain (but it is also not working :/)
  • Device is not supported -> Lenovo Yoga w/ Android 4.4.2
UDS internal:
C:\>nslookup
Standardserver:  mbit-s-int02.int.mbit-s.com
Address:  10.60.4.21
> set type=srv
> _cisco-uds._tcp.int.mbit-s.com
Server:  mbit-s-int02.int.mbit-s.com
Address:  10.60.4.21
_cisco-uds._tcp.int.mbit-s.com  SRV service location:
          priority       = 0
          weight         = 0
          port           = 8443
          svr hostname   = mbit-s-uc10.int.mbit-s.com
mbit-s-uc10.int.mbit-s.com      internet address = 10.60.4.10
The Device on CUCM is configured and connected with the User. Authentication works over a LDAP-Server.
Jabber 4 Windows on my Laptop is connecting and registering without issues. All is working fine (phone, presence, IM, ...).
Is it possible, that the Error is the "not supported" Tablet?
Thanks a lot!
Kind regards,
DrMxxxxx
P.s.: For easy Information: The error is in the attached txt file at the very end. (In Notepad ++ Line: 2359)
Update: On an iPhone (supported from Cisco) it is working... :/ Perhaps it is really an issue with an unsupported device. But eventually some of you had the same Problem and perhaps a solution. :)
0 REPLIES 0
Content for Community-Ad
Spotlight Awards 2021
