Highlighted
Enthusiast
Jabber IM for Android - android acore process has stopped
I'm running Jabber IM for Android on my tablet (Asus Transformer Prime) and smartphone (Motorola Bionic).  I've been running it successfully on both devices since the beta with little or no issue.  Since I upgraded both devices to 4.1 I'm getting force close errors: process android acore has stopped.  Does jabber IM for Android support android 4.1?   Are there any steps that can be taken to prevent this from happening?
1 REPLY 1
Highlighted
Enthusiast
Hi Kyle,
The product is supported on 4.1.  We have not heard of the issue you're running in to, so I would suggest you use the feedback option in the application to send us your logs and describe your problem.  We will investigate what the issue may be.
Thanks for your feedback!
Rena
Content for Community-Ad
