The guide provides all the basic ports that are required for an on-prem deployment, and states other guides might need to be reviewed for additional ports, if you're using MRA, it clearly states:
For information about port usage for Expressway for Mobile and Remote Access, see Cisco Expressway IP Port Usage for Firewall Traversal.
java
if this helps, please rate
