Jabber not showing Options menu under Settings
frankran
Beginner
Beginner
Jabber_for_Windows-11.8.0.49608
In Jabber, From the Settings Icon (Gear) Options menu is missing
How do I get the Options menu to show up under settings for Jabber only users
Mark Swanson
Enthusiast
Enthusiast
Try this... File > Options.
Hi Mark
Thanks for the tip
After more investigation, I found that there were several different versions of Jabber installed.
The user in question did have the Options menu - It was found under Settings\File and not directly under Settings
Fix was to upgrade to Vsn 12.6 - Options menu now shows directly under Settings
Will be updating all users with the same version
Frank
