Jabber not working with smartphones
Rafael Jimenez
Enthusiast
Enthusiast
hello,
I have cucm/cuc/cup 8.6.x. Cisco Jabber on iphone is not working for two days.
on Windows is working fine. the iphones are in the LAN.
The chat, voice messages works fine, the call drops after the other end answer the call.
I appreciate your help.
Thanks.
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
What troubleshooting have you done?
And have you verified compatibility??
You're running versions that are EOS/EOL
java
if this helps, please rate
reinstalling the app in the phone.
This instalation has several years working fine. But I see that Apple IOS  and jabber were updated recently.
yes.
Jaime Valencia
11.8 is the oldest shipping release right now, and it was compatible with 9.1+ in the backend, 11.9 and later need 10.5 as minimum.
Someone recently had some issues with Jabber and had to downgrade to a version which was compatible with their CUCM/IM&P.
You're running a not supported combo of Jabber and CUCM/IM&P releases.
I'd suggest you review CUCM traces and Jabber PRT and see if something stands out, but if you wish to use the latest Jabber releases, you need to upgrade the backend as well.
java
Recognize Your Peers
