12-14-2015 06:01 AM - edited 03-17-2019 05:44 PM
Cisco Jabber Audio Settings are not being saved or remembered after a reboot. I have set the audio settings to use the Headset Earphone/Microphone and clicked Apply then OK. Calls are sent and received properly through the headset. However, whenever Windows reboots, and Cisco Jabber opens, the Audio settings are automatically changed to use the built-in Speakers/Microphone. Please help.
04-16-2020 10:41 AM
This fixed it for me, the Advanced link is there at the bottom you need to scroll down to see it.
09-05-2017 03:20 AM
09-27-2017 12:37 AM
I know this is an older thread now, but just in case this helps someone else, here is the location of the file which stores the speaker, microphone, and camera preferences.
%appdata%\Cisco\Unified Communications\Jabber\CSF\Config
OR
C:\Users\USERNAME\AppData\Roaming\Cisco\Unified Communications\Jabber\CSF\Config
Filename:
deviceData3.properties
Jabber reads the file "deviceData3.properties" on startup and writes to it when changes are made to the speaker, microphone, or camera preferences. You can read the contents of the file with a text editor and even make your own changes. However, if you do make manual changes, the jabber client will need to be restarted as it appears the file is only read once initially and is not scanned for further changes when Jabber is running.
Here is an example of what some of the file contents look like:
Speaker-ID-0: USB\VID_046D&PID_0A44&MI_00
Speaker-Name-0: Speakers (2- Logitech USB Headset)
Speaker-SelectionID-0: {0.0.0.00000000}.{c780344e-7c62-450b-b47b-d88c1912e34c}
Speaker-Volume-0: 100
Speaker-DeviceInterface-0: \\?\usb#vid_046d&pid_0a44&mi_00#6&b879def&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global
Speaker-FriendlyName-0: Logitech USB Headset
Speaker-ID-1:
Speaker-Name-1: Remote Audio
Speaker-SelectionID-1: {3.0.0.00000001}.{6C26BA7D-F0B2-4225-B422-8168C5261E45}
Speaker-Volume-1: 100
Speaker-DeviceInterface-1:
Speaker-FriendlyName-1:
Microphone-ID-0: USB\VID_046D&PID_0A44&MI_00
Microphone-Name-0: Microphone (2- Logitech USB Headset)
Microphone-SelectionID-0: {0.0.1.00000000}.{22b8b43a-6e05-4f7f-b28b-fa15e9dd2d82}
Microphone-Volume-0: 40
Microphone-DeviceInterface-0: \\?\usb#vid_046d&pid_0a44&mi_00#6&b879def&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global
Microphone-FriendlyName-0: Logitech USB Headset
Microphone-ID-1:
Microphone-Name-1: Microphone (Logitech USB Headset)
Microphone-SelectionID-1: {0.0.1.00000000}.{5f39f9e5-c055-4f98-94b0-dbaf33e4044c}
Microphone-Volume-1: -1
Microphone-DeviceInterface-1: \\?\usb#vid_046d&pid_0a44&mi_00#6&30faff39&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global
Microphone-FriendlyName-1: Logitech USB Headset
Camera-ID-0:
Camera-Name-0: TANDBERG Video
Camera-SelectionID-0: \\?\usb#vid_1f82&pid_0001&mi_00#6&14a9a643&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
Camera-Volume-0: 80
Camera-DeviceInterface-0: \\?\usb#vid_1f82&pid_0001&mi_00#6&14a9a643&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
Camera-FriendlyName-0: TANDBERG Video
09-27-2017 01:39 AM
Hi Jonathan,
it's an interesting information of yours. I retain the static behavior of Jabber about the discovery of audio devices and this behavior could conduct to audio device loss.
From what I'm seeing on customer site, even a headset (Jabra, Plantronics,...) has been correctly priorized in the advanced settings, the same headset appears a second or a third time in the audio device list and only one is coloured in black. The other are greyed out.
Unfortunately the used audio device (same headset without any changes) seems to be newly discovered and is not placed on top of the list as configured.
A Microsoft MCSE has analyzed the headset driver and PnP discovery into Windows and has concluded that Windows makes his PnP job as usual.
Have you ever seen this behavior ?
Rgards,
Jacky
09-28-2017 08:42 PM
Hi Jacky,
I have not seen this behaviour before.
You may have some luck with opening a TAC case to dig further.
Have you been testing using the latest version of jabber?
10-06-2017 08:15 AM
Hi Jacky,
Were you able to repair this issue? I find that our audio preference list will change seemingly on its own from time to time. We use Plantronics audio devices for our Jabber softphone. I've been working with Plantronics Support to determine why the devices may be reordered in Jabber - perhaps due to power savings or PnP - but no luck thus far. I'm a little surprised reports of this issue aren't widespread across the web. Either it's something in our environment that causes this, or not many people are using Jabber as their softphone with an external audio device (or maybe it doesn't bother them)? In any case, it's big problem for us. Also, based on our experience and what I've read elsewhere, this doesn't seem to be exclusively related to Windows 10. In fact, we're using Jabber 11.7 on Windows 7 64-bit.
I commented on an old thread here which illustrates how easy it is to recreate this problem when you use Remote Desktop, but the problem is certainly prevalent even with users who don't use RDP: https://supportforums.cisco.com/t5/jabber-clients/jabber-v9-2-and-remote-desktop/m-p/2213342/highlight/false#M5892
10-16-2017 01:36 PM
Hi All,
I was able to resolve the issue. Thanks to another post in this list.
After testing a bunch of solutions, I was able to make the settings stick by modifying the file
C:\Users\user\AppData\Roaming\Cisco\Unified Communications\Jabber\CSF\Config
1- Log off jabber
2- Exit
3- Open the file in notepad++
4-Manually place the device you want in order and change their ID
For example If I want to use my computer speakers by default instead of the Sennheiser Dongle
FROM THIS:
Microphone-ID-0: USB\VID_1395&PID_002D&MI_00
Microphone-Name-0: Headset Microphone (Sennheiser BTD 800 USB for Lync)
Microphone-SelectionID-0: {0.0.1.00000000}.{ed0eb6da-101a-406d-9a37-7bcdc89871cf}
Microphone-Volume-0: 100
Microphone-DeviceInterface-0: \\?\usb#vid_1395&pid_002d&mi_00#6&7889738&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global
Microphone-FriendlyName-0: Sennheiser BTD 800 USB for Lync
Microphone-DeviceVendor-0: Unknown Vendor
Microphone-ID-1: HDAUDIO\FUNC_01&VEN_10EC&DEV_0668&SUBSYS_10431080
Microphone-Name-1: Microphone (Realtek High Definition Audio)
Microphone-SelectionID-1: {0.0.1.00000000}.{1a894faa-ba3c-4833-a3a3-adb202ca7654}
Microphone-Volume-1: 89
Microphone-DeviceInterface-1: \\?\hdaudio#func_01&ven_10ec&dev_0668&subsys_10431080&rev_1000#4&172bd3b9&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\rtmicinwave
Microphone-FriendlyName-1: Realtek High Definition Audio
Microphone-DeviceVendor-1: Unknown Vendor
TO
Microphone-ID-0: HDAUDIO\FUNC_01&VEN_10EC&DEV_0668&SUBSYS_10431080
Microphone-Name-0: Microphone (Realtek High Definition Audio)
Microphone-SelectionID-0: {0.0.1.00000000}.{1a894faa-ba3c-4833-a3a3-adb202ca7654}
Microphone-Volume-0: 89
Microphone-DeviceInterface-0: \\?\hdaudio#func_01&ven_10ec&dev_0668&subsys_10431080&rev_1000#4&172bd3b9&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\rtmicinwave
Microphone-FriendlyName-0: Realtek High Definition Audio
Microphone-ID-1: USB\VID_1395&PID_002D&MI_00
Microphone-Name-1: Headset Microphone (Sennheiser BTD 800 USB for Lync)
Microphone-SelectionID-1: {0.0.1.00000000}.{ed0eb6da-101a-406d-9a37-7bcdc89871cf}
Microphone-Volume-1: 100
Microphone-DeviceInterface-1: \\?\usb#vid_1395&pid_002d&mi_00#6&7889738&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global
Microphone-FriendlyName-1: Sennheiser BTD 800 USB for Lync
10-20-2017 01:02 PM
Thanks, Danik. I find that I too can edit this file the way you described if I want to control the list, however the order still changes on its own. Did you do anything more than simply edit the file? Perhaps you also restricted permissions to the file? I found that I can setup this file the way I want per your description and give the user read-only permissions to it which will force Jabber to order the devices correctly on clean launch, however they will still get reordered mid-Jabber session. In short, this method requires the user to exist Jabber and launch it to pull in the correct settings. This is close to working, but still not ideal.
Any other thoughts?
11-23-2017 06:27 AM
I have to confirm this behaviour of Jabber app. We are using 11.9.1 and by some users change the jabber app the setting during the day even if deviceData3.properties read-only is. Is there any news regarding this issue?
01-31-2018 06:06 AM
Anyone make any progress on this? We are having volume problems with out headsets. We are using 11.9.1 and VXME on our VDI environment. With VXME on both the thin client and VM. When disconnecting from the VM the microphone volume on the headset changes when connecting back to the VM. I've tried playing with volume in the devicedata3.properties file but that doesn't do anything. it doesn't seem to recognize the volume change for the microphone in that file. Anyone have any ideas? Thanks.
08-09-2018 03:58 AM
change the sequence of the speakers in the config file. Change also the device id. Only the first device with id=0 will be used after starting the application. The config file must configures as read only because the config file will be overwritten after every new starting of the application.
01-08-2020 09:26 AM
Thanks so much Danik for your solution here, which solved my problem immediately. The reality is simply that Jabber's UI has no way for users to specify preferences or priorities. In a world where pretty much everyone has multiple audio and video devices, this seems to be a critical design failure. How hard could it be to provide a method for overriding the static preferences that Jabber sets initially, which are most likely based on bad assumptions about what your hardware preferences are? Yesterday I was on a conference call and had to mute my mic because background conversations around me were interfering with the phone meeting. It was only afterward that I realized that Jabber had been using my webcam mic rather than my headset mic, and this escaped me at the time despite the fact that I've been constantly aggravated by this. Even if Jabber doesn't supply an interface for selecting preferences, how hard could it be for Jabber to assume that when you have a headset plugged in you want to use the headset? Unbelievable.
10-31-2018 08:30 AM
I also had encountered this issue on Windows 10 with Jabber 11.9 and 12.1.1.
I'd additionally found that after deleting the Jabber cache and then in Windows changing the default playback and recording devices, when restarting Jabber the default devices were then selected by default and always used. I could change the devices in options, but these changes would not persist after restarting Jabber.
However if instead of the Standard audio options, you click Advanced, then change the order of preferred devices, these changes do persist between restarts of Jabber / Windows.
Hope this helps. TAC apparently said "this is by design". I think it's a bit silly that you need to know to click on "Advanced" to persist the changes.
05-19-2020 01:06 AM
Thank you Paul.
I had the same issue jabber for Windows version 12.8.0.51973 build 301973. Changing my audio preferences via Settings - Audio - Advanced and re-ordering the speaker and microphone has resolved my issue also and the settings are now preserved session to session. It is indeed curios that settings are only preserved session to session if set under the advanced options.
All the best
Richard
07-12-2021 05:25 PM - edited 07-15-2021 12:45 PM
I can't get my audio settings to "stay put" and modifying the device preferences doesn't help. No matter what I do my ringer, speaker, and microphone device lists are randomly re-sorted every day and my default devices change. I'm logging into a Citrix MyPC environment and I'm using Cisco Jabber 12.9.1.53980 Build 303980. My properties file name is "deviceData4.properties".
I've tried
Here are some things I've noticed
I've been trying to diagnose and fix this for half a year. Can anyone offer any help?
