Jabber SDK Garbled Audio
cistera.com
We're currently using Jabber SDK to create a web-based softphone to be able to coach existing jabber calls.
In our tests, any call initiated by a web client to another cisco device or to a PSTN produces garbled audio.
Here is the test case and the results:
Source
Source Application
Destination
Destination Device
Source->Dest Audio Status (Garbled or not)
Dest->Source Audio Status
ISGRP18 (172.22.29.120)
Jabber Desktop Client
ISGRP08 (172.22.29.74)
Clear
Clear
IP Communicator
Clear
Clear
Jabber Web Client (Browser)
Clear
Garbled
External number
PSTN
Clear
Clear
Garbled
Clear
IP Communicator
Garbled
Clear
Garbled
Garbled
External number
PSTN
Garbled
Clear
What can cause this?
Here is the link of the actual recording played through from the packet capture:
https://community.cisco.com/t5/video/gallerypage/video-id/6308337062112
Thank you
Alexander Stevenson
Hi @cistera.com,
I would look through the Cisco Bug Search Tool and see if this is a know bug, perhaps with a known workaround.
https://bst.cloudapps.cisco.com/bugsearch
Best of luck!
Actually this issue seems to be caused by Windows RDP. Performing the same test locally had no issues, although, from the same remote workstation Jabber calls were 100% clear as well. Not sure what MS is doing with their "virtual" microphones, but it seems to be in their court.
