Jabber sends low resolution
Laszlo Olah
Dear Colleagues,
I have faced with a strange problem during a new videoconference installation.
The whole solution has two main components:
- UCM/IMP/CMS based infrastructure with jabber clients and conference rooms
- 3rd party call control/register server with SIP and H323 video endpoints
When I call a videoconference endpoint from jabber, the softclient sends 384x216 30fps only (but receives 720p30).
This low resolution appears only between the jabber and video endpoints, every other direction works perfectly:
- CMS room <-> video endpoint 1080p
- CMS room <-> jabber client 720p
- jabber client <-> jabber client 720p
We have only one region with 2048kbps bit rate for video and for immersive calls as well.
Does anybody any idea where can I find the solution?
Laci
Ratheesh Kumar
Hi there
Are you hitting this. If then please see the workaround and see that helps you.
Jabber for Windows sends poor resolution video if a peer works with Multistream mode being Auto
CSCvg69691
Description
Symptom:
Jabber for windows has 2 problems if a peer Telepresence endpoint is working with Multistream mode being Auto.
1. Jabber for Windows sends video with a poor resolution (384*214) to a peer Telepresence endpoint such as MX800Dual. An expected behavior is to use 1280*720.
2. Jabber for Windows is unable to share its desctop to a peer Telepresence endpoint such as MX800Dual.
It doesn't happen when Multistream is OFF.
Conditions:
Call flow:
MX800Dual ---- CUCM ---- Expressway-C ---- Expressway-E --(internet)-- Jabber for Windows
Workaround:
Set Multistream mode : OFF on the peer Telepresence endpoint side.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
R0g22
You would need to take a trace or a pcap to see what is being negotiated to see where the problem is. Setting the region defines the maximum rate b/w two endpoints in the region. A lower resolution/rate would still be allowed.
Thanks for the response.
I copied from the SIP trace the relevant SDP part of INVITEs and 200 OKs.
1st INVITE from Jabber
a=rtpmap:126 H264/90000
a=fmtp:126 profile-level-id=42E01F;packetization-mode=1;max-fs=3601;max-rcmd-nalu-size=32000;level-asymmetry-allowed=1
a=imageattr:126 recv [x=[32:1:1280],y=[18:1:720],par=1.7778,q=1.00]
a=rtpmap:97 H264/90000
a=fmtp:97 profile-level-id=42E01F;packetization-mode=0;max-fs=3601;level-asymmetry-allowed=1
a=imageattr:97 recv [x=[32:1:1280],y=[18:1:720],par=1.7778,q=1.00]
200 OK from Endpoint
a=fmtp:126 packetization-mode=1;profile-level-id=428014;max-br=2500;max-mbps=245000;max-fs=8160;max-smbps=245000;max-fps=3000
a=fmtp:97 packetization-mode=0;profile-level-id=428014;max-br=2500;max-mbps=245000;max-fs=8160;max-smbps=245000;max-fps=3000
2nd INVITE from Jabber
a=rtpmap:111 X-ULPFECUC/90000
a=fmtp:111 max_esel=1420;m=8;max_n=32;FEC_ORDER=FEC_SRTP
200 OK from endpoint
a=rtpmap:111 x-ulpfecuc/8000
a=fmtp:111 multi_ssrc=1;feedback=0;max_esel=1450;m=8;max_n=64;FEC_ORDER=FEC_SRTP;non_seq=1
Is there any problem with the profile-level-id?
Laszlo
Ratheesh Kumar
Hi there
CSCvg69691
Description
Symptom:
Conditions:
Call flow:
Workaround:
Hope this Helps
Cheers
Rath!
You were right, I have upgraded the client, it works perfectly now.
Thanks for the resolution,
Laszlo
