Jabber won't connect to voicemail off the corporate network
cnyengineer
Hello everyone,
We've got v11 of both CUCM and Unity, as well as version 8.9.2 of expressway-e and c. This has worked in the past and nothing changed to cause it to stop working as far as I know.
On Jabber mobile, under 'Voicemail', it tells me "Cannot connect to the voicemail server. Verify your account information. If the problem persists, contact your voicemail administrator."
I turned on detailed logging, cleared logs, and then tried to reconnect to try to get a fresh capture of what's going on and then attached the result to this post.
Any thoughts?
15 Replies 15
First check your backup and after that reboot your CUC Cluster in a maintenance window and see if the problem is solved.
If´s not i suggest you to open a case with Cisco TAC.
Leonardo Santana
*** Rate All Helpful Responses***
