Location of Setting: In a meeting
TheChoices
Where is the value stored for the following setting?
Options, Status, Let other users know when I am: In a meeting
Attempt 1:
%APPDATA%\Roaming\Cisco\Unified Communications\Jabber\CSF\Config\jabberLocalConfig.xml
I tried jabberLocalConfig.xml which stores many other settings (including other Status options), but the file does not change when I toggle "In a meeting" and click OK.
Attempt 2:
I could not find any relevant settings in files or registry keys below:
%APPDATA%\Roaming\Cisco\Unified Communications\Jabber\CSF\Config\*
Registry HKCU\SOFTWARE\Cisco\*
Registry HCKU\SOFTWARE\Cisco Systems, Inc.\*
Cisco Jabber, Version 10.5.1 Build 43318
Windows 7 Ultimate, SP1
Jaime Valencia
I believe that's in the actual code of Jabber, why are you looking for this??
java
if this helps, please rate
What do you mean by "in the actual code of Jabber?"  The value has to be stored somewhere.  The executable doesn't get rewritten.
I want to set that value programatically.  Most other settings can be changed via the jabberLocalConfig.xml file.
The "In a meeting" presence state is set when Jabber sees you in a meeting in Outlook. There is no file set for this; it's an in-memory decision.
PS- To my knowledge, editing the jabberLocalConfig.xml is not supported by Cisco.
