09-25-2021 06:51 AM
We have unity connection unrestricted version 10.5.2 running. Can we migrate to 11.5.X restricted version ??
Please suggest if any options.
Jagdish
09-25-2021 07:35 AM
You cant upgrade to restricted version.
Are you planning to use PCD for migrations ? if yes, AFAIK PCD doesn't support Unity migrations.
09-25-2021 09:43 AM
Use COBRAS, make sure to review the tool documentation and similar threads in the community.
09-25-2021 10:25 AM
Or update your current installation to the version you intend to be at and then install a new server with restricted version where you do a restore of a DRS backup.
10-04-2021 12:37 PM
this is the best option.......have done this several times myself.
