NSF Requirement for CMS Recording
muazam ali
HI All,
i am planning to deploy CMS recording and i would like to is it mandaory to have NFS to store recording or i can use BE6K local space to save recording ?
I have red Multiple Docs and been touch with cisco representative but i am getting different answers. can anyone help here.
Jaime Valencia
Documentation is pretty clear on the fact that if you want to use the recording feature, your need an NFS to store the recordings.
Where to place that NFS, or what system to use as NFS, is up to you.
java
if this helps, please rate
It means we have to use external file storage system. CMS recorder cannot
save recording on its own space.
Correct
java
