PC Port Remote Configuration and Switch Port Remote Configuration report
Hk15
hello everyone ,
i have to generate a phones report with specialy two importante field " PC Port Remote Configuration and Switch Port Remote Configuration" and i cannot find how to do it.
could someone can help me on this ? ,
many thanks for your help
2 Accepted Solutions
Jaime Valencia
Use BAT and filter per device type, as that is device specific configuration.
java
if this helps, please rate
Do an export all and they should be there
java
Jaime Valencia
java
Thank you jaim for your answer
 i already tried with bat and with filtring by device type ( device type that have this two paramètres field)  but it s impossible to get these two  parameters  in the « device field choice » in order to include it in the report
java
Thank you jaim, i got all entreprise paramètres in a xml format , i will try to manage with this format , because i need a report of 6000 phones but thank you again
