Peer-to-peer call between Cisco Spark app and standards-based endpoint
Deepak Mehta
Team,
I am referring to below doc where it says ,Audio, video, or media that does not pass through a Hybrid Media Node:
  • Audio from phones
  • Peer-to-peer call between Cisco Spark app and standards-based endpoint
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cloudCollaboration/spark/hybridservices/mediaservice/deployment/cmgt_b_hybrid-media-deployment-guide/cmgt_b_hybrid-media-deployment-guide_chapter_0100.html#reference_267223F468729132FF9E2C42CFA86550
So question if there are two internal spark clients within my enterprise , will the media/signalling goes to the cloud ?
Deepak Mehta
skilambi
Media will stay on video node if deployed
Signaling goes to the cloud
This is referring to a spark client making a p2p call to an endpoint on CCM or VCS which wouldn’t pass through the media node
Srini
6 Replies 6
skilambi
Srini
Hi Srini,
I guess i didn’t read the doc carefully and you are right.
It clearly says peer to peer calls  between spark and other video endpoints.
I believe in that case the call media will be established via expresway E and C to the interbal video endpoitns.
Thank you for quick response.
ssielaff
My understanding is without a media node, the media (Audo stream) will go to the cloud.  There is no peer to peer calling with spark.
With a media node, the audio will go to the media node if the connectivity is better than the connectivity to the cloud.
Yes correct that’s what I mentioned above p2p call with spark endpoints will use HMN for the connection assuming of course the STUN test all come out in favor of that
Srini
Hi Steve,
Signalling and media will go to the cloud however return path to the internal endpoint will be via Expressway E and C.
Let me know if you think this is not the case ?
Spark App-------------------Cloud---------------------Expressewa E- C----------------------CUCM ---------------------Endpoint
Yes that’s right assuming spark to CCM endpoints or VCS as I already mentioned above
Srini
