01-20-2015 11:54 PM - edited 03-17-2019 04:49 PM
Hi All,
I have Exp-E X8.2.2, Exp-C X8.2.1, and CUCM 9.1.2.
I have SX20 with firmware version TC7.
The MRA traversal is working fine beetwen Exp-E and EXP-C.
Is it possible for me to do this scenario?
1. SX20 with public IP and public DNS server
2. SX20 not registered to CUCM through Exp.
3. Making a call from SX20 to Jabber Windows
4. The scenario topology -->> SX20 > Exp-E > Exp-C > CUCM > Jabber Windows (Registered to CUCM)
I ever do this scenario on VCS Control and VCS Expresway. And it's work.
The scenario is:
2. SX20 not registered to VCS Expressway.
3. Making a call from SX20 to Endpoint registered to VCS Control
4. The scenario topology -->> SX20 > VCS-E > VCS-C > Endpoint registered to VCS-C.
Thank you..
Rois
02-09-2015 05:21 AM
Hello Muhamad,
I've done similar scenario and it's working fine.
Thank you,
Shadi
02-15-2015 08:27 PM
Hi Shadi,
Thank you for the reply.
Could you tell me please how the way?
Thank you,
Rois
02-15-2015 09:58 PM
Hello Rois,
SX20 can be configured to work as standalone, take a look at the link below which summarize the configuration steps:
http://www.experts-exchange.com/Hardware/Networking_Hardware/Q_28451585.html
Are both exp-e and exp-c configured properly with with CUCM? Did you try making testing calls from "Cisco Jabber Video for TelePresence"?
Are you able to make outgoing calls successfully (try calling 111@bjn.vc)?
Thank you,
Shadi
02-15-2015 10:40 PM
Hello Shadi,
Thank you for your reply.
Both exp-e and exp-c are configured properly with CUCM. I can making a call from internet with Cisco Jabber 10.5.3 to the private Cisco Jabber 10.5.3 and TC endpoint (registered to CUCM) and vice versa.
The scenario what i want is TC endpoint (SX20) on the internet (with public ip) is not registered to CUCM. Then TC endpoint (SX20) making a call to private Cisco Jabber 10.5.3 that registered to CUCM. The RMA trunk between exp-c and exp-e is working properly.
Do i have to make a different trunk between exp-e and exp-c for this scenario?
Thank you,
Rois
02-15-2015 11:07 PM
Hello Rois,
From SX20 are you able to make internet calls into other destinations?
I would like to check the logs, we can start collecting logs from the SX20 to see what is going on.
Thank you,
Shadi
02-15-2015 11:40 PM
Hi Shadi,
Yes, it can with H323.
Do i need to create another trunk between exp-c and exp-e for this scenario?
Yes, we can collect them.
Thank you,
Rois
02-16-2015 12:15 AM
As you configured SX20 to work as H323, can you confirm wither (LIC-EXP-GW: Enable GW Feature (H323-SIP) ) is uploaded and H323 is allowed?
Can you try configuring the SX20 as SIP instead of H323?
