Python script for adding IP phone
atifsheraz
Hi All,
I got a problem adding few variables in the python script as shown below. would be nice if someone could guide me.
 media resource group or “built-in bridge, owner user ID” for phone configuration below
You must refer the Axl schema https://developer.cisco.com/docs/axl-schema-reference/ and build a script. You must be able to do it the built tin bride and media resource group , User ID by using update phone option.
Why do you want to enable set the Media resource group on the phone. This can be set on the device pool level.
Built in bridge can be set using BAT, or it can be enabled from service parameter level.
For setting  owner ID  Cisco Device Assignment Tool will be helpful.
Response Signature
