Re: Question on Cisco Spark pyCiscoSpark module
dminh3651
Beginner
Beginner
   My name is Tom. I am new on Cisco Spark, and I would like to star learning on how to use it on my project.
First , I try to install pyCiscoSpark but I got the message saying pyCiscoSpark is not available. I wonder if you may know a way on how to install pyCiscoSpark.
 Thanks so much in advance,
Tom
Martin Koch
Advocate
Advocate
You do not need that pyhon library to do do stuff with Spark.
Besides that check out the readme file that will tell you more how the samples can be used:
https://github.com/brbester/pyCiscoSpark
I would recommend to check out
https://developer.ciscospark.com/
this is a good place to start to play around and has documentation and links to labs!
