Reject a call with Jabber Android
Attila Horvath
When I receive a call with my latest Jabber for Android, I can see only an Answer button.
Is it possible to reject a call?
(There is no Voicemail system installed, so cannot divert it to VM)
Jaime Valencia
Reject uses the VM configuration in order to send the caller to VM, that's the reason you don't have the option.
java
if this helps, please rate
Thanks for reply, thats what I think after search for answer.
But is there any trick or workaround to reject incoming calls (eg fake VM configuration),
or any other? At mobile word it is a must on a smartphone, and call reject is Judt a simple SIP opction.
Yes, you'd need a fake VM config to be in place so you get the reject option.
java
