RoomKit Plus P60 camera Speaker tracker with ceiling mic
markko.krause
Beginner
Beginner
Hello
have a question about using RoomKit Plus and Speaker tracker function in larger rooms. Is it possible to use Ceiling mic for better speaker tracker performance or does speaker tracker works only with integrated microphones in RoomKit.
Same question about RoomKit Plus with P60 camera.
Sandro Nardi
Contributor
Contributor
Hi Markko,
Speaker Tracking / best view functionality are based a lot on face recognition, in large spaces distance and light blur the face to much to be selected active speaker.
If you are not facing the camera, software will never pick you as the active speaker and even if it can detect the speaker you are limited to the quad cam zoom (x5).
Single P60 cam have no speaker track functionality, you can activate presenter functionality but works in a different way and do not use microphone.
Just to confirm, Cisco P60 camera does not support speaker track, right?
That is correct. The P60 will do Presenter Track, which is when the camera actively follows the presenter in a pre defined stage.
Recognize Your Peers
