Hello Team, I would like to know if Cisco call manager can generate administrator activity and event logs and forward it to a third party application for security related monitoring purpose? Call Manager Version: 11.5Best Regards,
The content you are looking for has been archived. View related content below.
Jabberがサポートするプラットフォームについてご教示ください。 事情によりVMware vSphere以外の選択肢の検討が必要になっております。 Ciscoサポートが受けられる仮想化プラットフォームは他にあるでしょうか。 また、仮想化ではなく、通常のWindowsサーバーにJabberを構築することは可能でしょうか。 よろしくお願いします。
I just received my first publicly signed certificate that does not include the client authentication key usage. Apparently this is an industry change happening: https://www.sectigo.com/resource-library/tls-client-authentication-public-ca-end-2026#...
Can I change the price list type , while I am trying to modify Flex Subscription on the same terms ?
We have a CUCM, PCCE, and agents with Spok integration and Telstrat call recording. we have complaints of dropped calls or hangups. in call traces we normall see a "bye" but both parties insist they are being hung up on. I found the following and ...
When we are connecting our domain laptop with cisco room bar using USB C-C active cable, camera gets detected and discovered in the meeting applications, but speakers and microphones is not detected. Even the option doesnt appears in meeting to selec...
We have a user that was issued a new laptop. It is running Windows 10 Pro and for whatever reason when she clicks on a screenshot in Jabber...it will not open to view. It shows the preview of the screenshot in Jabber...but when you click on it...it d...
We are working deployment of jabber application to all of our users. I see one of the notice about EOLhttps://www.cisco.com/c/en/us/products/unified-communications/jabber-windows/eos-eol-notice-listing.htmlEnd-of-Life Announcement for the Cisco Jabb...
I just migrated Unity Connection from version 11.5.1.15900-18 to version 15.0 SU2.Everything seemed to go smooth.But the DRF Master service stops as soon as I access anything on the DRS web page.This happens on both the Publisher and Subscriber. All ...
Hi everyone,I’m running Cisco Meeting Server 3.10.1 with Expressway-C/E X14.0.11.On my CMS, I’ve configured meetingapps on port 447 for survey and file transfer, and everything works fine when users connect on the local network.Recently, I configured...
Expressway cluster built on version 15.2.4. Operating, but throwing a weird error: Cluster peer 1 is specified as configuration primary, but for the replication to work properly peer 2 should be specified as configuration primary I have tor...
Hello,The Jabber version we are using is 14.1.4.58788,Some users report that they are seen online by others even though they are logged out,When we check, they are not using Jabber from another device, we cleared the caches and tried again but the pr...
Something must have changed with Jabber for Windows 15x. I cannot import contacts via xml file anymore. The same file works in jabber 14.3 but not in 15.x. Its a bit annoying to install 14.3 to import contacts and then upgrade to 15.xwhat exactly cha...
I have a scenario where I'm needing to update the server certificate on my Expressway Edges. The existing GoDaddy certs will expire in October. I have the renewed certificates from Go Daddy. I just had them renewed, I did not generate a new CSR. ...
We are in the process of replacing all of our Touch 10's with Room Navigators.Out of the 80 or so we've replaced, 2 rooms are having issues.Basically, any room nav connected to 2 Codec Plus's in particular are giving the error: "This Touch Panel Is U...
| Subject | Author | Posted |
| 11-27-2025 05:11 PM | ||
| 11-13-2025 04:17 AM | ||
| 11-12-2025 11:22 AM | ||
| 11-10-2025 01:44 AM | ||
| 10-09-2025 06:03 AM |
