AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
1101
Beginner
Spark Room Shortcut
In the Spark application is there a way to create/copy a shortcut or link for a specific Spark room?
6 REPLIES 6
Advocate
Re: Spark Room Shortcut
If its a space with more than one participant, if you click on the "Waffle" icon on top right, select "Meetings", it should give you the link to join a specific space. I am not sure if this is what you are after or looking for shortcuts within the Spark application.
Please rate useful posts.
Beginner
Thank you George for your reply. Your advice is helpful but not exactly what I need.
What I need is a link for a space that I can send via chat or email that will direct them to the team space.
Highlighted
Advocate
If you want a way for people to join a space, take a look at the "Eurl" bot. (eurl@sparkbot.io).
Beginner
Can't find this on the spark depot. Can you advise how this works pls?
Advocate
You invite the bot to the space just like you would with any other bot/person.
Once you invite the Eurl bot to your space, how does one determine the url for that specific space so that the link can be copied and shared?
Content for Community-Ad
August's Community Spotlight Awards
