505
Highlighted
Spark SX10 customize
Is it possible to change the background image ?
Our Customers would like to use their company logo
Philippe CUVILLIER
3 REPLIES 3
Highlighted
Contributor
Re: Spark SX10 customize
If they are Spark registered, then they should be able to click the Advanced Settings option under the Device in the Admin Portal.  Then go to Setup>Personalization.
If it's on-prem registered, then just hit the IP address from a browser, login, and do the same process.  Setup>Personalization.
With most customers that want to use their logo, they need to create the background in photoshop or gimp, and then make sure the size aligns with the limits that Cisco sets for the wallpaper. (Only BMP, GIF, JPEG and PNG files smaller than 16 megapixels are supported. Custom wallpapers do not apply to touch panels.)
Highlighted
I dont find the admin page, do you have a url ?
The only thing I have is this :
Highlighted
Beginner
