09-24-2013 07:48 AM - edited 03-17-2019 03:33 PM
Is it possible to create a global speed dial list in Jabber? Ideally, I would like to create a custom tab in Jabber and have the speed dials listed there. If this is possible, what code would I have to put in the jabber-config.xml?
Thank you,
Danny
Solved! Go to Solution.
09-26-2013 09:02 AM
All you would do in the XML file is provide a URL to whatever web server is going to serve up the HTML code.
Please remember to rate helpful responses and identify helpful or correct answers.
09-26-2013 01:11 PM
Covered in the same document two pages farther down.
Chats and Calls from Custom Tabs
You can use protocol handlers to start chats and calls from custom embedded tabs.
Use the XMPP: or IM: protocol handler to start chats.
Use the TEL: protocol handler to start audio and video calls.
For more information, see the Protocol Handlers topic.
Related Information
09-26-2013 09:02 AM
09-26-2013 12:28 PM
I have done what you have mentioned; however, all I have is a list of names and numbers. How do I make a hyperlink so when the user clicks on the name/number, Jabber will automatically dial the number? Is this possible?
Danny
09-26-2013 01:11 PM
Related Information
09-26-2013 01:12 PM
I got it working now.
Thank you very much for your help!
Danny
