configure & troubleshoot anyconnect
375
Highlighted
Beginner
Trouble upgrading SX20 firmware
Hi all
I need to know if there is a special firmware version for an SX20 with which I can connect to the Webex platform in China.
I heard that it had to be a specific firmware for a theme of keys or encryption
Or what version is compatible
My device has this version
Software version:
TC7.2.0.aea6651
1 REPLY 1
Re: Trouble upgrading SX20 firmware
is it a standalone endpoint ? or registered somewhere?
also the TC7.2.0 is very old software and deferred as well from cisco.com
Cisco always recommend to use the latest software as it has the most of bug fixes and stable version.
As you are running on very old software You need to first upgrade your codec to TC7.3.0 and then to TC7.3.6 and then any latest software.
Please find the below release notes for TC 7.3.x
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/software/tc7/release_notes/tc-software-release-notes-tc7.pdf
Please rate if it is helpful...
Content for Community-Ad
June's Community Spotlight Awards
