Unity connection configuration issue
eigrpy
Level 4
Level 4
Hi Please see picture attached. I am trying to do the initiate configuration for Unity Connection. The issue is that the button Edit cannot have any reaction to any click. Any suggestion? Thank you
Vaijanath Sonvane
Have you tried using Chrome or Firefox browsers?
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
try different browsers (Chrome, Firefox) .
if you are using older version of unity connection, try the compatibility mode in IE.
