09-25-2019 12:55 AM
Hi Folks, New install of Unity version 12.5 and all works except when either dialling the voicemail pilot number or pressing the messages button and the call is answered by unity with "Enter your ID followed by hash" rather than going to the inbox for messages. The call is coming into Unity with the correct calling number according to port monitor. I did import the users etc from an older 10.0 system using COBRAS.
Any Ideas please?
09-25-2019 03:05 AM
Hi Paul,
1- when either dialing the voicemail pilot number or pressing the messages button
- When you dial Voice mail pilot number and press message , what you hear exactly and what is the output of Port monitor.
2- the call is answered by unity with "Enter your ID followed by hash" rather than going to the inbox for messages.
- Please test and share port monitor ouput
09-25-2019 06:02 AM
Hi Hari, Symptoms as per original post. It is something in the COBRAS restore as I built a new instance of unity and it worked just fine. A soon as I restored the V10.0 backup to new V12.5 system, the fault symptoms re-appeared.
09-25-2019 06:32 AM
09-25-2019 06:37 AM
09-26-2019 11:15 PM
OK folks - just an update. It turned out there was a direct routing rule called Sign-In that was present on the old V10.0 system that was the problem. Luckily I had noted what routing rules we had on a virgin install and compared to when I installed the backup as I was suspicious about the routing rules. Anyhow, I removed this Dial-In rule and it all came back to me as expected.
09-27-2019 07:47 AM
09-27-2019 07:48 AM
