Webex Meeting issue
Hi all,
I am facing an issue with Cisco Webex, every time there is a meeting invite on Webex, it takes like 30-40 minutes in loading and this is only happening on our internal network, if we will try to join the meeting from outside network it works fine.
Please if I can get some guidelines on how to resolve this issue.
It will be really helpful
Thanks and Regards,
Zaheer Jahangir
keglass
Level 7
Level 7
Zaheer,
This sounds like an issue for WebEx technical support. WebEx Technical Support is available 24/7 to assist you with all of your technical services needs. Please refer here for contact information:
Contact WebEx Technical Support | WebEx
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
