09-08-2022 10:08 AM - edited 09-08-2022 10:11 AM
A coworker said the Webex Room Kit Plus can use PresenterTrack and SpeakerTrack at the same time. However, I see only one camera input. Am I missing something or is the Webex Room Kit Pro required for solutions requiring front and back autotracking cameras in the same design?
thanks,
Solved! Go to Solution.
09-08-2022 12:26 PM - edited 09-08-2022 12:42 PM
Not an AV expert myself but hopefully the diagram and link below helps.
https://help.webex.com/en-us/article/n4522teb/Set-up-Classroom-on-Cisco-Webex-Room-Devices
09-08-2022 02:39 PM
Thanks. That helps so much. I usually worked on large scale systems with a local network switch. This info confirmed some of my ideas outside of the "Cisco box." Thanks again!
09-08-2022 06:14 PM
Great! No problem. Glad you found it helpful.
