05-12-2015 07:45 AM - edited 03-17-2019 05:09 PM
Not sure if this is the right sub community.
We have an on premise WebEx version 2.5
Presently if you do not log into an account within 30 days , your set to inactive.
Where can I change this ? somewhere I read it could be 30, 60 or 90 days. is there an indefinite?
Phillip
Solved! Go to Solution.
05-12-2015 07:51 AM
Hi Phillip,
If you go to CWMS Administration > Settings > Password Management > User Inactivity Options, you will see the option: Deactivate host account after day(s) of inactivity . If you Uncheck the option and save the changes, it will be indefinite when it comes to CWMS rules for inactivity.
I hope this helps.
-Dejan
05-12-2015 07:51 AM
Hi Phillip,
I hope this helps.
-Dejan
