03-21-2016 10:35 AM - edited 03-17-2019 05:58 PM
Does anyone know when there will be a firmware release to allow the DX80 endpoint to be compatible with Spark? Is this something that happened with the "Cisco DX Series Firmware Release 10.2(5)SR2" or is it still something that we are waiting for? Any information anyone has would be helpful.
Thank you
08-31-2016 08:27 AM
I have this issue as well. Just tried to install Spark from Google Play and get message "Your Device is not compatible with this version." Any updates as to when DX80 compatibility will be available?
08-31-2016 06:40 PM
When you install the new CE8.2.x software on to the DX80, you can then register it to Spark.
See https://help.webex.com/docs/DOC-8948
Wayne.
07-21-2017 03:58 AM
Wayne, you need to be clearer on this.
CE8.2 converts the DX80 to CE mode and it only runs Spark. You also need the appropriate device licenses on your Spark account to add the DX80 as a device. Connecting it to CUCM in CE means it is a telepresence endpoint.
All android type features disappear and it becomes a single use endpoint. I think what is being asked for it to be able to use the android feature tablet type version with the android client as you would do with a phone.
