We have UCCX and are using cisco finesse. We have deployed popup screen feature on finesse and it is working fine, but we have a problem. It does not create new tab for each call that is handled and every new call over writes the call info with the new call info. How can I have new tab for each call that it handled?
1 Comment
gtunugunta
Hello Smith,
I believe, you are using gadgets to display call information when a new call arrives.
If yes, please explore jquery and jquery-ui to create a tab for every call. You have to create a new tab when a new dialog event occurs.
You can find examples in below links.
https://www.oreilly.com/library/view/jquery-ui/9781449325176/ch02s05.html
https://stackoverflow.com/questions/2416547/how-to-add-and-remove-jquery-tabs-dynamically/2430311
Best regards,
Gangadhar Tunugunta.
