Walkthrough Wednesdays
CUIC reporting for CVP Post Call Survey
1302
cdnadmin
Advisor
This document was generated from CDN thread
Created by: Gajanan Pande on 20-02-2012 08:59:19 AM
Can CUIC pull a report of CVP Post Call Survey ?
Post call survey will be saved in CVP Reporting server & I believe CUIC can pull reports from CVP Reporting server.
All I need to confirm is does CUIC have a standard reporting template for this or it needs a customized one ?
GP.
Subject: RE: CUIC reporting for CVP Post Call Survey
Replied by: Gajanan Pande on 20-02-2012 09:24:38 AM
Thanks Senthil, yes PCS data will be stored in CVP Reporting server. So can we write a query to dig CVP Reporting server DB like you mentioned for AW DB ?
GP.
Replied by: Senthil Kumar Natarajan on 20-02-2012 09:16:54 AM
GP.
No built in. You need to write your query to dig in the DB for the post survey results. In my deployment, we had the PCS survey results stored as a Call Type data in the AW/HDS DB. I not sure of the PCS data stored in reporting DB, unless your CVP application is taking the PCS responsiblity (in my case it was ICM, except for bridging the call)
-senthil
Replied by: Senthil Kumar Natarajan on 20-02-2012 09:38:10 AM
GP.
Personally i haven't done it myself but i see no reason why it can't be done. You need to know the schema and the DB you are pulling from and a correct query.
Here is one i found on courtest callback stored on CVP reporting DB.
https://supportforums.cisco.com/docs/DOC-15368
-senthil
1 Comment
pheadden
Beginner
Can you write a query/report in CUIC to join the CVP results with the Agent extension in the HDS TCD table?
Or, can you create a report in CUIC to report on data from multiple data sources?
Content for Community-Ad
