dekwan
New versions of the Finesse Sample Gadget have been posted!
  • The Finesse gadgets can be downloaded from the Sample Gadgets page. Click the sample gadget that you are interested in, then download the version that matches the Finesse system.
  • There were no changes to the gadget specs between 11.0.1, 11.5.1, 11.6.1, 12.0.1, and 12.5.1 so 11.0.1 gadgets will work as is on 11.5.1, 11.6.1, 12.0.1, and 12.5.1.
Whats new?
  • Starting Finesse 10.6.1 (which is a UCCX release only):
    • The Finesse JavaScript Library (finesse.js) and the jQuery Library (jQuery*.min.js) are hosted on the Finesse server itself. The files can be found under: http(s)://<FQDN>:<port>/desktop/assets/js/finesse.js & http(s)://<FQDN>:<port>/desktop/assets/js/jquery.min.js. As a result of this change, the sample gadget zips will no longer contain these files and do not need to be uploaded to the web server with the gadget files.
    • The Finesse JavaScript Library documentation is hosted on the Finesse server itself. It can be accessed with the following URL: http(s)://<FQDN>:<port>/desktop/assets/js/doc/index.html
  • Starting Finesse 11.0.1:
    • In addition to the Finesse JavaScript Library and documentation being hosted on the Finesse server as explained above, the finesse.gadget.Config is now built into the finesse.js and the user's id can be obtained from the config.
    • Since the Finesse JavaScript Library files are now hosted on the Finesse server itself. Moving forward, these gadgets should not need any changes after a product upgrade unless there are significant changes in the new finesse.js file where it is not backwards compatible. When this happens, a new gadget version will be posted with the starting version number.
Convert your 10.5.1 gadget for 10.6.1
1. In the gadget's xml, change the following imports from:
     <script type="text/javascript" src="jquery-@jquery.version@.min.js"></script>
     <script type="text/javascript" src="finesse-@finesse.js.version@.js"></script>
          to
     <script type="text/javascript" src="/desktop/assets/js/jquery.min.js"></script>
     <script type="text/javascript" src="/desktop/assets/js/finesse.js"></script>
     If your gadget is hosted on the third party server, use the absolute URL.
2. Optional. Remove the old jquery-@jquery.version@.min.js & finesse-@finesse.js.version@.js files as they are no longer needed
Convert your 10.5.1 gadget for 11.0.1/11.5.1/11.6.1/12.0.1/12.5.1
1. In the gadget's xml file, change the following imports from:
          to
2. In the gadget's js file, remove the following code:
finesse.gadget.Config = (function () {
    /** @scope finesse.gadget.Config */
    return {
        authorization: finesse.utilities.Utilities.getUserAuthString(),
        country: prefs.getString("country"),
        language: prefs.getString("language"),
        locale: prefs.getString("locale"),
        host: prefs.getString("host"),
        hostPort: prefs.getString("hostPort"),
        extension: prefs.getString("extension"),
        mobileAgentMode: prefs.getString("mobileAgentMode"),
        mobileAgentDialNumber: prefs.getString("mobileAgentDialNumber"),
        xmppDomain: prefs.getString("xmppDomain"),
        pubsubDomain: prefs.getString("pubsubDomain"),
        restHost: prefs.getString("restHost"),
        scheme: prefs.getString("scheme"),
        localhostFQDN: prefs.getString("localhostFQDN"),
        localhostPort: prefs.getString("localhostPort"),
        clientDriftInMillis: prefs.getInt("clientDriftInMillis")
3. In the gadget's js file, if you have code to get the user's id like this:
     var prefs =  new gadgets.Prefs(),
     id = prefs.getString("id");
          ...change it to...
     var cfg = finesse.gadget.Config;
4. To get the user's id, you must first call the ClientServices.init,
         finesse.clientservices.ClientServices.init(finesse.gadget.Config);
     then, you can access the id with:
          cfg.id;
5. Optional. Remove the old jquery-@jquery.version@.min.js & finesse-@finesse.js.version@.js files as they are no longer needed
Convert your 10.6.1 gadget for 11.0.1/11.5.1/11.6.1/12.0.1/12.5.1
1. In the gadget's js file, remove the following code:
    return {
2. In the gadget's js file, if you have code to get the user's id like this:
          ...change it to...
3. To get the user's id, you must first call the ClientServices.init,
          cfg.id;
4 Comments
rafael.beier
Enthusiast
Enthusiast
Hello
i'm trying to convert my Gadgets but i'm not able to find the files on our UCCX 10.6.1
We are using UCCX 10.6.1, but when i try to open the link http://UCCXServer/desktop/assets/js/doc/index.html
no file found. the same with Finesse.js and jquery.min.js
What i do wrong or where can i get the files?
Best regards
Rafael
dekwan
For UCCX, Finesse uses https so the URL will most likely be https://UCCXServer:8445/desktop/assets/js/doc/index.html. The best way to figure out the full URL is to go to the Finesse desktop page, then modify the URL to be /desktop/assets/js/doc/index.html.
pavelekshin
Beginner
Beginner
@dekwan
Hi, do you have update for Finesse 12.X ?
dekwan
Thank you for the reminder. I updated the blog to include 12.0.1 and 12.5.1. Basically, the 11.0.1 gadgets will work on 12.X and no changes are needed.
Thanx,
Denise
Recognize Your Peers
