Simple password control for making outbound international or longdistance call
496
Advisor
This blog was generated from CDN blog
Created by: Yaw-Ming Chen on 12-09-2012 01:42:17 PM
If you just need a simple password control for long distance or international call and don't want to use RADIUS, you can set a parameter in service then in script ask caller to enter password if it matched the one set in IOS configuration then make the call out otherwise disconnect call. A sample script is posted in Documentation section.
2 Comments
I am looking for this example, but can't seem to find it anywhere.  Can you help me find it?
Best regards,
LC
you can find the sample script in below link.
Re: How to Set Conference Password for Meetme Bridge
Raghavendra
Content for Community-Ad
August's Community Spotlight Awards
