This document was generated from CDN thread
Created by: null on 01-04-2003 11:54:57 PM
I'm using Nuance VWS, and found (pg 46 of the user guide) that for external grammars the slot must be called foundation_fld. I did that and got the slot value returned in the [b:d78eedb62c]value [/b:d78eedb62c]element data.
So far so good.
I also would like to get the actual words spoken, in addition to this [b:d78eedb62c]interpretation [/b:d78eedb62c]or slot value.
I note in the audium log that the [b:d78eedb62c]uttereance [/b:d78eedb62c]is logged (the transcription of the actual words spoken). The user element specs (forms element) say [quote:d78eedb62c]The matched utterance and interpretation are saved for the duration of the session. [/quote:d78eedb62c] but there is no documentation of what element or session data contains it.
Also, does audium support multi-slot external grammars?
If so how? (I don't know how to specify a slot name, since in the case above it was implicitly foundation_fld)
Subject: RE: accessing return values from external grammars
Replied by: null on 05-04-2003 12:00:26 AM
Currently, the Audium Form (with Confirm) elements do not store the actual utterance as element data but it is logged in the application log files. Future releases will add functionality and support for more shadow variables for the Form element. However, it is possible to build your own custom element with the current release that will provide your with the functionality you are looking for, or you may also use a vxml insert element.
If you are using VWS 2.0 or NVP with the Form element, you can use a grammar that fills multiple slots. However, in this case, you should NOT have any slot that is named "foundation_fld". The value that is stored in "value" will be a string that contains all the slot name/value pairs. For example, if the grammar has as slot names "lastname", "name" & "firstname", you would get the following result:
voice input - "mary lee"
stored in "value" - {lastname="lee" name="mary lee" firstname="mary"}
utterance logged - mary lee
Most likely, you will want to process the element data at some point after the element has collected the input.
Joe
