cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: David Oxley on 20-08-2013 09:04:17 AM
I believe I have stumbled across a bug in version 8.5 of the AXL API for Call Manager - specifically, "getPhone" does not return roamingDevicePoolName when requested. We're using CUCM 8.6.2.23046-1.
This functionality works* on the same Call Manager when exercised with the 7.1 API, but not when the 8.5 API is employed. I've attached some sample requests/responses. Note that it's the same call manager and the same application user in each case; the only thing that changes is the version of the API.
* - well, it returns a UUID rather than a name, but I can live with that.
This seems like a bug to me (getPhone happily returns everything else that we've asked for) but would be happy for someone to point it out if I'm making a mistake.
David
Subject: RE: AXL (8.5) getPhone does not return roamingDevicePoolName
Replied by: David Staudt on 21-08-2013 04:49:29 PM
This is likely a defect, where roamingDevicePoolName is not implemented, but before generating a defect ID need to request a few details:
- Is the device in fact roaming and registered in an EMCC configuration at the time of the request?
- If not, any chance that device pool with UUID of  '1a1de63b-f3af-9044-527e-2c0b66132246' is in fact named 'FOO'..?
- Assuming the above check out, can you enable the detailed level AXL logs and attach here? http://developer.cisco.com/web/axl-developer/gather-axl-logs
Replied by: David Oxley on 22-08-2013 08:52:58 AM
David,
Thanks for the reply.
I'm not sure what you mean in terms of EMCC configuration (we're not using Cross Cluster Extension Mobility) but, yes, the device is roaming. By this I mean the phone displays the message "Device in Roaming Location" and when I click "View Current Device Mobility Settings" I see that the Roaming Device Pool field is populated. (I'd include a screenshot but I can't see how to attach things to a reply.)
Actually no. At the time of my initial post,
1a1de63b-f3af-9044-527e-2c0b66132246 was actually BAR:
1admin:run sql select name from devicepool where pkid = '1a1de63b-f3af-9044-527e-2c0b66132246'
2name
3====
4BAR
(we've since swapped them around for other testing, hence the edit.)
Yep - I wanted to get ball rolling with a reply - I'll append the logs shortly.
Thanks again,
David
gdewinter
Hello All,
I am working in V10.5 and seem to have the same issue. Is there already a solution?
Best regards,
Geert Dewinter
