Walkthrough Wednesdays
BIB and RTP port
292
Subject: RE: BIB and RTP port
Replied by: David Staudt on 25-04-2010 05:34:40 PM
AFAIK this is not possible.  What is the use case?
This document was generated from CDN thread
Created by: Fabrice Brenzi on 25-04-2010 04:56:04 PM
We are developing a recorder.
We have the following system:  Call Manager 6, Cisco Phones 7942 and 7962
When a recording session is invoked (automatically), a SIP trunk is established between the CM and my recorder server. The BIB / Build-In-Bridge of the agent phone delivers two RTP streams to the recorder server.
CM INVITES my recorder to both calls via SIP Trunk. My recorder accepts both calls and receives two RTP streams from the device BIB.
My problem is that I'm trying to obtain, through JTAPI, the value of the RTP port used by the agent BIB phone to send the RTP stream to the recorder. Is there a way to access this information?
Through JTAPI, I only access the information about the CALL between the agent and the caller and not the CALL between the agent BIB phone and the recorder.
Is that possible with JTAPI to get RTP Input/Output parameters about the agent BIB phone for the call corresponding to the CALL between the agent BIB phone and the recorder?
Replied by: Abhishek Malhotra on 26-04-2010 11:31:26 AM
Correct.
This isnt possible from JTAPI as of today.
Replied by: Fabrice Brenzi on 02-05-2010 05:37:27 PM
In the SIP message received by the recorder from the Call Manager, the SDP information is as follows:
          Media Description, name and address (m): audio 4000 RTP/AVP 0 101
The port number (4000) indicated in this SDP is not the real value used by the BIB / Build-In-Bridge of the agent phone.
The recorder needs to know the value of the RTP port used to send the RTP stream to the recorder.
Is there another way or technology to access this information?
Content for Community-Ad
