Created by: Geoffrey Carman on 28-02-2013 11:39:34 AM I made the following call: <soapenv:Envelope xmlns:ns="http://www.cisco.com/AXL/API/8.5" xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"> <soapenv:Header/> <soapenv:Body> <ns:updateDeviceProfile sequence="?"> <name>EM_Profile_70001</name> <mlppIndicationStatus>Off</mlppIndicationStatus> <preemption>Default</preemption> <lines> <lineIdentifier> <index>1</index> <label>Name New Last Name1 70001</label> <display>Name New Last Name1</display> <displayAscii>Name New Last Name1</displayAscii> <missedCallLogging>true</missedCallLogging> <directoryNumber>70001</directoryNumber> <routePartitionName>PT Line 1</routePartitionName> </lineIdentifier> </lines> </ns:updateDeviceProfile> </soapenv:Body> </soapenv:Envelope>
I got a success message: <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"> <soapenv:Body> <ns:updateDeviceProfileResponse xmlns:ns="http://www.cisco.com/AXL/API/8.5"> <return>{F4B7FAD3-B68A-6126-0848-0A54981BD67C}</return> </ns:updateDeviceProfileResponse> </soapenv:Body> </soapenv:Envelope>
That is returning the DeviceProfile GUID (Based on the URL I see in the CUCM Admin UI). This correctly changed the Line 1 assignment from 70005 to 70001 on the Device Profile named EM_Profile_70001. But none of the 'demographic' info changed. Am I missing something here? I do know that I changed from using <line> to <lineIdentifier> based on info provided in another thread, which was required to succeed at addDeviceProfile.
How do the <line> and sibling <lineIdentifier> interact, in the DeviceProfile API calls?
Subject: Re: New Message from Geoffrey Carman in AXL Developer - Administration XML Replied by: Sascha Monteiro on 28-02-2013 01:46:24 PM I never use the linceIdentifier, not sure how it's correct syntax would be, try <lines> <line> .. </line> </lines>
> Geoffrey Carman has created a new message in the forum "Administration XML > Questions": -------------------------------------------------------------- > I made the following call: > <soapenv:Envelope xmlns:ns="http://www.cisco.com/AXL/API/8.5" > xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"> > <soapenv:Header/> > <soapenv:Body> > <ns:updateDeviceProfile sequence="?"> > <name>EM_Profile_70001</name> > <mlppIndicationStatus>Off</mlppIndicationStatus> > <preemption>Default</preemption> > <lines> > <lineIdentifier> > <index>1</index> > <label>Name New Last Name1 70001</label> > <display>Name New Last Name1</display> > <displayAscii>Name New Last Name1</displayAscii> > <missedCallLogging>true</missedCallLogging> > <directoryNumber>70001</directoryNumber> > <routePartitionName>PT Line 1</routePartitionName> > </lineIdentifier> > </lines> > </ns:updateDeviceProfile> > </soapenv:Body> > </soapenv:Envelope> > > > > I got a success message: > <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/ > "> > <soapenv:Body> > <ns:updateDeviceProfileResponse xmlns:ns="http://www.cisco.com/AXL/API/8.5 > "> > <return>{F4B7FAD3-B68A-6126-0848-0A54981BD67C}</return> > </ns:updateDeviceProfileResponse> > </soapenv:Body> > </soapenv:Envelope> > > > That is returning the DeviceProfile GUID (Based on the URL I see in the > CUCM Admin UI). > This correctly changed the Line 1 assignment from 70005 to 70001 on the > Device Profile named EM_Profile_70001. But none of the 'demographic' info > changed. > > Am I missing something here? I do know that I changed from using <line> > to <lineIdentifier> based on info provided in another thread, which was > required to succeed at addDeviceProfile. > > How do the <line> and sibling <lineIdentifier> interact, in the > DeviceProfile API calls? > -- > To respond to this post, please click the following link: > http://developer.cisco.com/web/axl-developer/forums/-/message_boards/view_message/12484626or simply reply to this email.
