Created by: null on 08-02-2005 11:47:37 AM Having created an application via "new project", and slected any logging level, how can this be changed? Perhaps a closely related question, how do you get to "general settings" for an application after it is created in Eclipse?
Subject: RE: Changing logging for a 3.4 application Replied by: null on 08-02-2005 03:39:53 PM To view the application settings of a project, you can do one of two things:
Select the project in the project pane, right-click, and choose propertied from the dropdown menu.
Select the project and go to the Project Menu and select properties.
This will display a box showing all the project properties. Three entries are Audium-related that contain the same screens you see in the wizard when you create a new project.
